Hatches
Skiffel
Hatches
Inlägg av Skiffel » sön 30 jun 2019 12:16
Hi My 1968 iF boat has no fore hatch has any one replaced the original with a production hatch. or can any one suggest a replacement
any comments welcome
thanks Tim
Been liked: 7 times
Re: Hatches
Inlägg av maja » ons 03 jul 2019 11:36
If there is no original hatch (or at least an original hatch opening), your boat is likely to be a 1967 model. The first 27 boats were designed with no forward hatch and no main bulkhead between the cabin space and forepeak space.
What is your manufacturing number? It should be engraved on the Marieholm building plate.
It is risky to open a great hatch without making proper reinforcements around the opening. Maybe you may inspect the hatch opening of another IF-boat to get an idea of how it could be done.
Skiffel
Re: Hatches
Inlägg av Skiffel » ons 03 jul 2019 14:23
Hi
The boat has had a hatch and has all the interior moulding. The opening is covered with plywood screwed down to the original raised sealing flange. So I could make a plywood covered with glass epoxy.
but, there are so many of these boats that i thought some one may have found a way of replacing the original.
thanks
Tim
cron
