Sökningen fann 19 träffar
av Captain_frog
lör 13 jan 2018 12:25
Kategori: Common
Tråd: Polar diagram for IF
Svar: 2
Visningar: 970
Re: Polar diagram for IF
Tank you very much for that info, I will have a look!
av Captain_frog
tis 02 jan 2018 20:54
Kategori: Common
Svar: 2
Visningar: 970
Happy New Year!
Has anyone a copy of a polar diagram for If boot. I could not find any on the Internet.
av Captain_frog
tis 02 jan 2018 18:04
Kategori: Common
Tråd: Outboard well
Svar: 17
Visningar: 3015
Re: Outboard well
And here the last series
av Captain_frog
tis 02 jan 2018 18:01
Kategori: Common
Tråd: Outboard well
Svar: 17
Visningar: 3015
Re: Outboard well
Here is another series of pictures!
av Captain_frog
tis 02 jan 2018 17:58
Kategori: Common
Tråd: Outboard well
Svar: 17
Visningar: 3015
Re: Outboard well
Hello Slag
Here are somme picture of the trap door!
av Captain_frog
lör 28 okt 2017 14:21
Kategori: Common
Tråd: Outboard well
Svar: 17
Visningar: 3015
Re: Outboard well
Hello Skald You are welcome. If you look for my thread "Motor angle in well" you will see some pictures of the exhaust fitting and the cooling water outlet. I you are interested, I might be able to send some picture of the dual door trap when my boat is out of water. To make it, I took the original ...
av Captain_frog
tor 26 okt 2017 21:50
Kategori: Common
Tråd: Outboard well
Svar: 17
Visningar: 3015
Re: Outboard well
Hello Skald I have an IF boat (1973) which I bought with a motor already in well (Mercury Sail Pro 6 HP 4 stroke with large Mickey Mouse propeller and remote control). I built a dual trap door to cover the opening. It can be opened from the motor compartment so I am able to remove the motor if I hav...
av Captain_frog
tis 18 jul 2017 08:59
Kategori: Common
Tråd: Repaint my boat
Svar: 1
Visningar: 825
Repaint my boat
Hello I plan to repaint my boat this winter. It was painted by the previous owner for the first time in 2010: 2 x ”International PRE KOTE” 2 x ”International TOPLAC” Mauritius blue 1 x ”EPIFANES Clear Varnish” UV Filter The question is: do I need to sand only the top layer and put 1 or 2 x TOPLAC or...
av Captain_frog
lör 01 apr 2017 12:02
Kategori: Common
Tråd: Windos in main sail
Svar: 2
Visningar: 1319
Windos in main sail
Hello Does anyone know the dimensions and the position of the small window in main sail (the window nest to the mast which allows a look on the genoa tell-tale? Windows in Main sail.png Is it as practical as it is supposed to be? Is the normal window (the big one next to the foot leech) also nice to...
av Captain_frog
tor 29 okt 2015 17:40
Kategori: Common
Tråd: Old winsch
Svar: 0
Visningar: 1301
Old winsch
Hej! While refurbishing my old winch I discovered that some small rubber bumpers are missing (broken loose). Does anybody knows who was the manufacturer of this type of winch, and if the parts are still available? If not any idea of a way to fix it so that the metal to metal contact is avoided? Than...
av Captain_frog
sön 18 jan 2015 22:16
Kategori: Common
Tråd: Cable type
Svar: 4
Visningar: 2551
Cable type
Hello Sailors
I would like to install an Anchor light (LED 1,5 watts) on the mast top of my IF. What kind of cable should I use in the mast to be sure it does not produce short cuts and how should I proceed to be sure it does not get entangled with the main halyard.
Any suggestion is welcome
av Captain_frog
mån 05 jan 2015 22:57
Kategori: Common
Tråd: Rubber for wndows
Svar: 3
Visningar: 2254
Re: Rubber for wndows
Thanks a lot for your answers and happy new year! In the mean time I found some Construction Sealant which seems to work It is sold in Germany under the name Building and Window Silicone: Versatile sealing (http://www.probau.eu/index.php?id=90&M=0&L=1&cHash=2e14faedf12db72df331ec5f16b7d356) Mean cha...
av Captain_frog
tor 25 dec 2014 21:32
Kategori: Common
Svar: 3
Visningar: 2254
Rubber for wndows
Merry Christmas and Happy new year to you all! one of my IF folkeboot fenster is leaking bad. I took it out today. The rubber is in very bad condition. It has been glued many time and falls into pieces. Is it possible to order this rubber a shop? If not what would be the best solution to make the wi...
av Captain_frog
sön 09 nov 2014 22:20
Kategori: Common
Tråd: Motor angle in well
Svar: 7
Visningar: 4223
Re: Motor angle in well
Hej! Here are some photos You can see at the back of the boot (she is now in Berlin) the control jet water running (right) an the exhaust fume (left). The control jet fitting is a garden hose fitting which has been widen to fit on the outlet (11 mm diameter) and is hold in place with a metal plate a...
av Captain_frog
mån 03 nov 2014 20:55
Kategori: Common
Svar: 7
Visningar: 4223
The previous owner of my boot had 3 very good solutions. He fixed a tube under the control water jet outlet to eject the water at the rear of the boot He fixed two metal fittings on the 2 smal exhaust outlets in the upper part of the shaft (glued with some kind of metal cement) and fixed a double pl...
