Svenska IF-båtförbundets forum • Winch removal
Winch removal
Postat: 12 sep 2014 13:49
av aadewar
Hello, we are going to replace our winches with Anderson bottom handle winches-but..
How hard is access to the mounting? It looks like there is no way to get to the underside of the base. Is it through-bolted?
Thanks!
Aaron
Re: Winch removal
Postat: 12 sep 2014 14:47
The plates of the winches are simply fastened from above by wooden screws. You will get access by dismounting the mechanics of the winch. Then use a large screwdriver... 8)
Re: Winch removal
Postat: 13 sep 2014 03:03
av aadewar
Thank you, I shall sleep easier!
