Svenska IF-båtförbundets forum • M26 vs iF boat - Original Tord S. Hull Drawings and Rig Spec
Postat: 22 aug 2010 20:58
av skiziks33
Does anyone know if the original Tord Sunden/Marieholm line drawings and spec sheets are available for the M26?
The IF boat drawings are available, so perhaps they're to be found on a swedish site somewhere?
Are there any notable material construction differences between the if boat and the M26, such as deck core, hull-deck joint, mast step, shroud-deck hardware etc?
Re: M26 vs iF boat - Original Tord S. Hull Drawings and Rig Spec
Postat: 22 aug 2010 21:16
As I understand the M26 has identical lines as the IF-boat. The only diference is the deck, cockpit and cabin lauyouts. Maybe the freeboard is a bit higher, but if so, this has certainly been done by a simple extrapolation of frames curves.
