Sökningen fann 11 träffar
av kjacobsen
30 apr 2014 22:37
Kategori: Common
Tråd: IF rig clevis pin sizes
Svar: 1
Visningar: 7668
I am unsure of the clevis pin sizes for my standing rigging terminals. Is it 8mm diameter f :?: or 10mm for the forestay, and 10 mm for the uppers, and 8 mm for the lowers?
Thanks
K Jacobsen
Charleston, South Carolina, USA
av kjacobsen
11 nov 2012 18:21
Kategori: Common
Tråd: IF transom thickness
Svar: 2
Visningar: 10746
Re: IF transom thickness
Marek: Thank you for the information. I am moving my outboard motor (6HP Tohatsu 4 Stroke) from the well to the transom using a stainless steel bracket and angle adapter. It will be mounted using 4 stainless steel 8 mm dia bolts. I am making a backing plate of 25mm plywood for the inside of the ...
av kjacobsen
08 nov 2012 23:26
Kategori: Common
Svar: 2
Visningar: 10746
What is the thickness of an IF boat transom? I am making the backing plate for an outboard bracket and need to calculate the total thickness.
Thanks
K.C. Jacobsen
Charleston South Carolina, USA
av kjacobsen
25 sep 2010 01:21
Kategori: Common
Tråd: IF Boat engine location plans
Svar: 0
Visningar: 7557
I am considering installing a diesel inboard in my boat. The boat is an outboard model with no inboard engine beds. Are there any plans or blueprints available that show the general location of engine bed, stern tube, rudder cutout ect. for a diesel installation?. Tak. K. Jacobsen Charleston South ...
av kjacobsen
25 sep 2010 01:21
Kategori: Common
Svar: 7
Visningar: 23551
av kjacobsen
14 jul 2009 00:42
Kategori: Common
Tråd: sheet winch base access
Svar: 2
Visningar: 10647
I have Lewmar genoa sheet winches mounted on the cockpit coaming. I am considering replacing them with Andersen winches, but am unsure about access to the fastenings from underneath. How can I remove the bolts holding the winch bases in place? Is there a backing plate? Thank You K. Jacobsen ...
av kjacobsen
25 apr 2009 18:03
Kategori: Common
Tråd: roller furl or hank on jib?
Svar: 1
Visningar: 8951
I've used hank-on jibs on all the boats I've owned because the sail always seems to set better than roller furling. However, I am now considering installing a RF jib with a FURLEX furler on my IF, for convenience in single handed sailing. Here are my questions: Do IF owners usually sail with the ...
av kjacobsen
27 sep 2007 06:25
Kategori: Common
Tråd: IF forestay and pin diameter
Svar: 1
Visningar: 7816
I am planning to replace my forestay. Is the correct wire diameter 5mm or 6 mm. Is the correct clevis pin diameter 8mm or 10mm
Thank you
K. Jacobsen
av kjacobsen
21 mar 2007 21:01
Kategori: Common
Tråd: Happy New Owner of IF 2595
Svar: 7
Visningar: 21288
I have been looking for an IF for some time, and yesterday bought one at the EBay auction. I sold my other boat, a 1961 Alberg 35' sloop because I wanted a smaller boat, and the folkboat has always been close to my heart. Next month I will be shipping the boat to my home in Charleston, South ...
av kjacobsen
18 nov 2006 03:44
Kategori: Common
Tråd: IF Construction and problem areas
Svar: 7
Visningar: 17873
Thank you to all for the information
I am still looking for the right IF boat. The information you all supplied will be of great help
Thank You,
Tak
K. Jacobsen
av kjacobsen
14 nov 2006 15:53
Kategori: Common
Svar: 7
Visningar: 17873
I am selling a bigger boat and looking for an IF. One area I'm unfamiliar with is hull and deck construction. Is the hull solid or cored? is the deck solid or cored? If it is cored, is is balsa or Airex (divinycell)? Are there any common problems such as hull blisters, hull/ deck joint, mast step ...
