Sökningen fann 5 träffar
av otter
22 aug 2011 06:58
Kategori: Common
Tråd: spinnaker topping lift block height on mast
Svar: 3
Visningar: 14136
Hey Sailors, I am adding a spinnaker to my rig and need to know what height on the mast above the lower spar band the turning block for the topping lift is secured . It doesn't appear to state the measurement in the class rules. Thanks, otter.
av otter
22 mar 2009 01:40
Kategori: Common
Tråd: broken mast
Svar: 12
Visningar: 25689
Re: broken mast
Thanks again maja. All excelent information.
Respect to all aspect, otter
av otter
20 mar 2009 17:59
Kategori: Common
Tråd: broken mast
Svar: 12
Visningar: 25689
Re: broken mast
Thank you very much maja. I have reviewed the drawings and made sense of them. Is an aluminum thru bar an acceptable method of attatchment?
av otter
20 mar 2009 14:06
Kategori: Common
Tråd: broken mast
Svar: 12
Visningar: 25689
broken mast
I have broken the mast on my boat and am trying to put one together from a similar extrusion.I am using the class rules as a guide line. I plant to make an aluminum thru bar for the spreader attatchment. Does anybody know the angle of rise from thw horizontal that the spreaders make, and what the ...
av otter
04 dec 2006 04:00
Kategori: Common
Tråd: inboard diesel
Svar: 3
Visningar: 11902
inboard diesel
I am looking at buying an IF that has an outboard. Is it possible to put a volvo md1b in a folkboat or would the weight deter too much from the performance?
