Sökningen fann 14 träffar
av Crazy Mary IF2670
21 aug 2018 14:07
Kategori: Common
Tråd: Electric drive conversion
Svar: 18
Visningar: 49196
Re: Electric drive conversion
Any update on that?
22 jun 2018 09:17
Kategori: Common
Tråd: AUTOHELM 1000 INSTALLATION
Svar: 8
Visningar: 22474
Re: AUTOHELM 1000 INSTALLATION
Thanks! You saved the day!
19 jun 2018 16:14
Kategori: Common
Svar: 8
Visningar: 22474
https://raymarine.app.box.com/s/nwf2s5h ... 3468872721
this is the one I have and I think it does not switch to otherside. But I will try.
19 jun 2018 16:00
Kategori: Common
Svar: 8
Visningar: 22474
There is a possibility to change operating sense för port mounting. Link to the manual: https://www.boatoon.com/de/shop/details/expose/raymarine-st2000-plus-pinnenpilot-2192/ Read pages 49-50 in the manual: Reversing the operating sense If necessary, reverse the operating sense can be reversed as ...
19 jun 2018 15:53
Kategori: Common
Svar: 8
Visningar: 22474
According to manual I need to place it on the starboard side ( thanks.... engine is there also :oops: ). I need to drill the deck. She is in original gelcoat on deck and hull. I do not have courage to drill her. I appreciate if someone can send me pictures of an installed autopilot, at least I will ...
18 jun 2018 17:05
Kategori: Common
Svar: 8
Visningar: 22474
I am trying to avoid to open a subject that has been ( should have been) discussed in the past, but I could not find it both in English and Swedish side. I got an ancient autohelm 1000, I think it is from - pre-Raymarine times but it works. I have stuurautomaat on the fuse box and the cables, but I ...
04 jun 2018 09:36
Kategori: Common
Tråd: Gennakker and/or Super Genua
Svar: 2
Visningar: 10237
Re: Gennakker and/or Super Genua
Thank you very much for your reply. My mind is clear now.
On Sunday I had chance to sail her with very light wind- close reach... she was still faster than almost all the 40ft light displacement boats with giant gennakers and code 0 getting nervous about the small boat passing them!
29 maj 2018 16:13
Kategori: Common
Svar: 18
Visningar: 49196
I think if you can make a rudder which is a good solution for you to work on. then you can find a donour to install your rudder to test, I believe rudder can be replaced while the boat is in the water. I think it is much easier than asking someone to cut his rudder :shock:
29 maj 2018 16:10
Kategori: Common
Svar: 2
Visningar: 10237
Hi, Well I know there is a very conservative part of Marieholm community ( making fun of my furling system that I also find it funny looking on Marieholm but also handy especially single-handed sailing). Anybody installed furler for Gennaker? I know there is an example already in Netherlands and ...
25 maj 2018 17:29
Kategori: Common
Svar: 18
Visningar: 49196
Hi, It is good to hear that. First I have checked the minnkota and torquedoo, especially torquedoo get a lot of awards and they worked with Hanse 315 for the electric one, I found them a bit expensive and they really do not have a commercialized solution for the rudder, I think they did the rudder ...
24 maj 2018 10:00
Kategori: Common
Svar: 18
Visningar: 49196
Hi, Congratulations, it sounds like a dream! I have been checking the pod motors to laminate on the rudder of my IF, I have seen that some of them can generate electricity while sailing (propellor turns the motor other way around to generate electricity), do you have such function? I also find out ...
24 maj 2018 09:53
Kategori: Common
Tråd: Outboard well
Svar: 17
Visningar: 34777
Re: Outboard well
Hi, I am also suffering from the bracket at the back and I had 4hp Yamaha ( 5 knots) that cannot be tilt up, the prop was in the water while sailing ( cannot give up from my even 1/4 knots as I am going after/with 40 ft boats :shock: )... I am replacing her with 5hp Mercury Sailpower; it is charging ...
22 maj 2018 14:49
Kategori: Beslag
Tråd: Anderson Parts
Svar: 3
Visningar: 10554
Re: Anderson Parts
Hi, Thanks for the replies, I removed the broken ones, actually NL distributor checked with Andersen factory and they informed me that they can supply the plastic teeth but winches worked well and I did not notice any additional friction or sound... Sorry that I could not reply you, first I was busy ...
14 maj 2018 19:36
Kategori: Beslag
Svar: 3
Visningar: 10554
Anderson Parts
Hi, I am new to the form. I checked ( in Swedish :) ) but I couldn’t find similiar post. I am overhauling IF 2670 - C. Mary I disassembled the Anderson winches. Luckly NL distributor has the small parts kit but they do not have the broken plastic teeth. What is the function of it? 8BAAAE45-D22B-4F8C- ...
