I found that Dilunett Gel remover (an unfortunate name for a product designed to leave gel intact) softens old contact adhesive sufficiently for it to be removed with a wet scourer. Do wear gloves though or it will burn your skin.
John
Sökningen fann 4 träffar
- 01 mar 2008 19:16
- Kategori: Common
- Tråd: Removing the glue from the interior
- Svar: 2
- Visningar: 10183
- 10 maj 2007 17:26
- Kategori: Common
- Tråd: Control lines - best way to lead aft?
- Svar: 15
- Visningar: 36083
Euan, I have old Lucas Main and genoa sails which you can have for nothing if you want to collect them. They are not good enough for serious racing (except perhaps in stronger winds) but they are at least the right size. I believe that you can get stick on sail numbers so changing the numbers should ...
- 09 maj 2007 10:23
- Kategori: Common
- Svar: 15
- Visningar: 36083
- 12 feb 2007 15:25
- Kategori: Common
- Tråd: Pintle erosion?
- Svar: 6
- Visningar: 17961
Pintle Wear
Michael, I have just had to replace my pintles because of considerable wear. It occurs to me that it is quite difficult to achieve perfect alignment of the three pintles and that consequently one of them is going to wear through constant pressure on one side of the gudgeon. It is probable that the ...
