Sökningen fann 10 träffar
av YotMax
25 sep 2009 13:17
Kategori: Common
Tråd: port and starboard chainplate backing
Svar: 3
Visningar: 10776
Re: port and starboard chainplate backing
Hi iamsville,
I don't have any photos or drawings but I can tell you that the chainplate backing on my M26 are just pieces of plywood, about 15mm thick and maybe 150x100mm (from memory), sealed and painted to protect them from moisture.
av YotMax
04 aug 2009 10:54
Kategori: Common
Tråd: Dropping the mast
Svar: 1
Visningar: 8095
Dropping the mast
I had a minor disaster on Sunday and hope you can give me some advice. I've been gradually replacing all the running rigging on the boat over the past months. I'd replaced a number of lines without trouble so far. The last to be done was the headsail halyard and, as luck would have it, I'd got it ...
av YotMax
23 mar 2009 10:36
Kategori: Common
Tråd: Open sea capability
Svar: 14
Visningar: 44949
Re: Open sea capability
This is obviously a well read topic with much interest in it! I have done negigible blue water sailing and never in an IF or in storms so won't add any comments. What I can add (for any who, like me hadn't seen it) is a blog I came across a few days ago about a crossing from England to Australia in ...
av YotMax
12 feb 2009 23:58
Kategori: Common
Tråd: In or out?
Svar: 7
Visningar: 17833
Re: In or out?
Thanks for all the responses, that's fantastic info. I've been away lately and haven't been to the boat for probably a month or more... I don't recall Sundancer having a shorter jib track such as those you mention. But if she doesn't then it's a simple enough job to install some. Certainly seems ...
av YotMax
05 jan 2009 03:55
Kategori: Common
Tråd: In or out?
Svar: 7
Visningar: 17833
In or out?
Folks, Still another newbie question... this time on jib sheets. Do you rig yours inside or outside the shrouds? Mine are currently outboard of the shrouds. Comparing with another M26 in our area and his are the same, outboard of the shrouds. But it looks wrong. The jib leads are aft of the ...
av YotMax
05 jan 2009 03:37
Kategori: Common
Tråd: Inboard diesels
Svar: 3
Visningar: 11847
Re: Inboard diesels
Hi Marek, A previous boat of mine (not an IF) had a transom mounted bracket on which the outboard lived. The problem that I found was that the weight of the outboard suspended aft of the stern tended to cause the stern to bury itself and drag. This was a much lighter boat (only around 600 kg ...
av YotMax
04 jan 2009 10:50
Kategori: Common
Tråd: Mast height
Svar: 3
Visningar: 11746
Re: Mast height
Thanks for your replies everyone. You've confirmed for me that I should say clear of that mooring. I've since applied for a mooring on the Parramatta River in Sydney Harbour. The only bridges I'll need to go under are 20+ metres. No problems there! :lol:
av YotMax
30 dec 2008 06:43
Kategori: Common
Tråd: Mast height
Svar: 3
Visningar: 11746
Mast height
Hi everyone, Hope you don't mind but I have another newbie question for you. Essentially, I am just trying to work out the height of the mast above the water line for my M26. I am looking at a potential permanent mooring spot but it would mean passing under a bridge that has 11.5 metres clearance ...
av YotMax
24 nov 2008 02:34
Kategori: Common
Tråd: Rig tension
Svar: 2
Visningar: 9138
Re: Rig tension
Thanks, maja. That's an excellent resource - well explained, logical and easy to implement too.
av YotMax
21 nov 2008 12:46
Kategori: Common
Tråd: Rig tension
Svar: 2
Visningar: 9138
Rig tension
Hi everyone, I recently purchased a nice little M26 which I am very happy with. But last weekend, I was laying in the v-berth looking up through our foredeck hatch and noticed that the mast has a bend to port above the spreaders. So the starboard capshrouds need a bit more tension. Or the port ...
