Is rudder hardware available?
aadewar
Inlägg av aadewar »
Hello, now we are replacing and repairing things at a tremendous rate!
Is hardware available for the rudder? Our pointless are worn, and the special barrel bolts did not survive disassembly.
Thanks!
Re: Is rudder hardware available?
The pintles are pressed into the fittings and are easy to retrofit by any mechanical workshop.
The bolts may be ordered from Göran Helmer in Strömstad, Sweden.
Been thanked: 81 times
Probably you do not know Swedish. Try to use some web based translator. Most times the resulting English will make sence, especially when you know what it is about... 8)
aadewar
Inlägg av aadewar »
I have had some repairs done in the boatwright's machine shop, but we will still purchase the special bolts.
Contact Göran Helmer through http://marieholmboat.se/ . You will find the contact details under "Information" .
Latest address information from Google/Eniro:
Göran Helmer AB
Telephone No: 0526 - 139 60
Postal address: , Brunnsgatan 13, SE-452 37 STRÖMSTAD
Also try www.seacamper.net (Berlin, Germany)
