Pintles and Jib tracks
Hopefully get my hands on the new boat this weekend! Yay!
Two questions.
(1) Anyone know what material the pintles and gudgeons are made out of? Seems to be a bit of play in the rudder, but I don't really have the option of getting the boat out until she's delivered home. What diameter are they? If there is just a little play will it be okay?
(2) Had a look at some pics on the site and it seems that some folks have short inner tracks. Are these just for the jib? My boat lacks them anyway, is there an official class measurement of where they must be placed and how long they must be?
Cheers
Two questions.
Cheers
Hi Euan,
Have at look at the class rule on this site (go to The Boat / class rule). It says it's swedish only, but there is actually an English version too. The diagrams are also very useful.
I don't think there is a rule about positioning of genoa tracks. We have an extra track which we use for the No. 2 jib.
For UK Marieholm's there is an override rule that allows new boats to the fleet to qualify as class legal as long as no alterations are made to the boat after it first arrives. I think any alterations subsequent to the boat's arrival must be in line with the international class rules. Len Careless will probably be able to clarify this.
Regards
Matt
Regards
Matt
Mathilde
GBR 7854
GBR 7854
Ah, so nows the time to say that she already has a 12ft carbon bowsprit, masthead assymetric, and water ballast fitted?musdavis skrev:Hi Euan,
Thanks for that Matt.... I need to get over to St Mawes and have a look at some boats. Who has the best sorted boat in the fleet?
Doh, shouldn't have told you that yet! The purpose of the rule is to encourage participation without the need for immediate expensive alterations.
Haven't actually had much of a look at any of the other boats. If you take a look at the race results though you'll see that 'Tringa' tends to clean up. Len's 'Pele' (inboard engine) might be more comparable to your boat. They normally race two up so everything must be pretty well sorted.
Mathilde
GBR 7854
GBR 7854
Re: Pintles and Jib tracks
The play has no really meaning for safety, more that it is irritating.euanb skrev: (1) Anyone know what material the pintles and gudgeons are made out of? Seems to be a bit of play in the rudder, but I don't really have the option of getting the boat out until she's delivered home. What diameter are they? If there is just a little play will it be okay?
IF-boats maufactured later than 1973 have rudder with rows transversally engraved to fit O-rings preventing play.
The pintles are made from brass. The pintles may be pressed out from the fitting by a hydraulic press and replacement may be manufactured from a brass rod of suitable diameter.
Depending on the position, short inner tracks may be used either for the working jib or for the genua.euanb skrev: (2) Had a look at some pics on the site and it seems that some folks have short inner tracks. Are these just for the jib? My boat lacks them anyway, is there an official class measurement of where they must be placed and how long they must be?
Tracks for the jib are to be placed about an inch from to the cabin side and the nuts and washers of the fitting screws being inside the hanging locker (i.e. track longitudinal position about outside the forward window).
Tracks for the genua are to be placed not more than 10 centimetres inside the toe rail. It is suitable to use a 40 centimeter long track starting about 65 centimetres aft of the upper shroud.
Inner genoa tracks are retrofit made by the owner. As you mentioned this is intended for making the boat to point higher, especially in light to moderate wind and waves.euanb skrev: Wonder why my boat lacks the inner tracks? Was it a later addition to help the boat point upwind better?
Jib tracks (always inner) was, sometimes but not always, yard´s supply, When being yard´s supply, they were (unforunately) placed somewhat too far aft.
