Mandatory closets inside.
(possibly in Swedish somewhere but couldn't find it)
I have an adapted interior but know that a wardrobe must be present during competitions. I'm thinking of a panel that I put on during races, much like a picture shows.
Is this sufficient or should a side panel also be present.
I can also make a narrower panel with the same height but narrower.(Like the new IF)
The question then is whether a side panel is also needed.
I'd love to hear how it's done, vrgr Adri van de Velde
https://photos.app.goo.gl/7qGT5wfXcsssmDGs6
https://photos.app.goo.gl/FY6bowc7jfJfiSz59
- 20180523_161216.jpg (95.54 KiB) Visad 10610 gånger
- 161216-IF-_01-semi.jpg (45.81 KiB) Visad 10610 gånger
- Been thanked: 81 times
Re: Mandatory closets inside.
There has to be a wardrobe with a width of at least 350 mm. The wardrobe height must be at least to deck level and it must have a front with an opening or a door.
In my opinion your pictures show something that is not allowed. There is no front, the height isnt't enough and one side is missing. That is simply not a wardrobe.
Let's see what other users think!
Thx,
There is a picture missing of a kind of additional panel (the old one as an example).
Maybe this one is something?
or has it to have a side panel as well at deck level?
Otherwise, I can make a smaller (350mm) front panel to deck level with a side panel to the hull.
And put the whole thing behind the lower front panel that already exists, just during races.
Is that an idea?
Is that an idea?
- Spotgaaibinnen1.jpg (72.39 KiB) Visad 10587 gånger
- Spotgaaibinnen2.jpg (71.63 KiB) Visad 10588 gånger
Also add a top cover to make it a complete wardrobe or, alernatively, make the vertical panels higher so they reach the inside of the Cabiin ceiling.
Okay, I think I get it.
I will make a small (35cm) front panel at deck level with an opening and a side panel to deck level included a cover.
So that will be (more or less) as in the new IF from seacamper.
First I will make it demountable but when it looks not bad I can consider making it permanently
Many thanks for your help
I will have my IF as light as possible but within the rules for races
Reg, Adri van de Velde Spotgaai NED1417
Next stage, on my way.
Better, right?
Better, right?
- Kast2.jpg (85.7 KiB) Visad 10394 gånger
Looks nice. Do not forget the top cover .
(cannot be seen on the photo).
The result of some homework to make Spotgaai according the rules
- hangkastIFb.jpg (67.15 KiB) Visad 9607 gånger
