Hello, now we are replacing and repairing things at a tremendous rate!
Is hardware available for the rudder? Our pointless are worn, and the special barrel bolts did not survive disassembly.
Thanks!
Is rudder hardware available?
Re: Is rudder hardware available?
The pintles are pressed into the fittings and are easy to retrofit by any mechanical workshop.
The bolts may be ordered from Göran Helmer in Strömstad, Sweden.
- Been thanked: 81 times
This thread may be of interest: http://www.ifboat.com/phpBB3/viewtopic.php?f=2&t=871
Probably you do not know Swedish. Try to use some web based translator. Most times the resulting English will make sence, especially when you know what it is about...
I have had some repairs done in the boatwright's machine shop, but we will still purchase the special bolts.
Contact Göran Helmer through http://marieholmboat.se/ . You will find the contact details under "Information" .
Latest address information from Google/Eniro:
Göran Helmer AB
Telephone No: 0526 - 139 60
Postal address: , Brunnsgatan 13, SE-452 37 STRÖMSTAD
Also try www.seacamper.net (Berlin, Germany)
Göran Helmer AB
