Sökningen fann 24 träffar
av aadewar
03 okt 2014 01:59
Kategori: Common
Tråd: Is rudder hardware available?
Svar: 5
Visningar: 13633
Re: Is rudder hardware available?
I have had some repairs done in the boatwright's machine shop, but we will still purchase the special bolts.
av aadewar
30 sep 2014 03:34
Kategori: Common
Svar: 5
Visningar: 13633
Hello, now we are replacing and repairing things at a tremendous rate!
Is hardware available for the rudder? Our pointless are worn, and the special barrel bolts did not survive disassembly.
Thanks!
av aadewar
13 sep 2014 03:03
Kategori: Common
Tråd: Winch removal
Svar: 2
Visningar: 9039
Re: Winch removal
Thank you, I shall sleep easier!
av aadewar
12 sep 2014 13:49
Kategori: Common
Tråd: Winch removal
Svar: 2
Visningar: 9039
Winch removal
Hello, we are going to replace our winches with Anderson bottom handle winches-but..
How hard is access to the mounting? It looks like there is no way to get to the underside of the base. Is it through-bolted?
Thanks!
Aaron
av aadewar
12 sep 2014 13:46
Kategori: Common
Tråd: Cabin leak
Svar: 8
Visningar: 22757
Re: Cabin leak
We had a lot of leaks in our boat, most under the lifeline stanchions, and one under the inboard jib track-that took some time, both to find and fix.
av aadewar
26 aug 2014 15:00
Kategori: Common
Tråd: Boltrope?
Svar: 6
Visningar: 16104
Re: Boltrope?
I imagine there are many, I hope to keep things simple. We may just go back to a boltrope-but thank you for your quick reply, it makes sense.
av aadewar
26 aug 2014 13:33
Kategori: Common
Tråd: Boltrope?
Svar: 6
Visningar: 16104
Re: Boltrope?
Well, we did put slides on the sail, but things are not as they were on our old IF. With the stop in place, the sail is held too far from the boom for reefing, and the sail stacks so high as to make it difficult to fit the cover, and it is difficult for my wife to fit the halyard. The channel for ...
av aadewar
24 jul 2013 20:59
Kategori: Common
Tråd: Boltrope?
Svar: 6
Visningar: 16104
Re: Boltrope?
Thank you! Our previous IF had sliders/travellers, and this boat has some other differences as well.
Aaron
av aadewar
23 jul 2013 20:11
Kategori: Common
Tråd: Boltrope?
Svar: 6
Visningar: 16104
Boltrope?
Hello,
At last we are getting close to launching our IFboat!
When we inspected our sails, we found the main was equipped only with a boltrope. Does anyone else have that on their IF?
We hope to sail soon..
av aadewar
09 mar 2008 16:18
Kategori: Common
Tråd: Removing the glue from the interior
Svar: 2
Visningar: 10173
Thanks, John, I'll look for a US equivalent.
Aaron
av aadewar
23 feb 2008 18:32
Kategori: Common
Svar: 2
Visningar: 10173
Hello,
We have removed the quilted lining from the cabin on our IF, and we want to remove the old glue that remains.
We have tried mineral spirits and WD40, but it seems to be stubborn.
Is there any trick that is known?
Thank you,
Aaron
av aadewar
12 maj 2007 16:04
Kategori: Common
Tråd: Chainplate eybolt replacement
Svar: 3
Visningar: 11337
Thank you-those are very different. Is it possible to buy them frm the US? We don't have an association as far as I know. I recall replacing uppers and lowers. Many owners expressed concern about the original eyes, but I remember the originals seemed in good shape. Perhaps I'll remove and inspect ...
av aadewar
11 maj 2007 23:37
Kategori: Common
Svar: 3
Visningar: 11337
Hello-on our first IF we replaced the eyebolts for the chainplates with a Wichard part as recommended on the forum. I want to do it on the "new" IF. I can't find the part number. Can anybody help?
Aaron
av aadewar
05 maj 2007 16:30
Kategori: Common
Tråd: Anchor/rode storage ideas
Svar: 0
Visningar: 6883
Hello!
We are trying to decide how to stow our anchor/rode as conveniently as possible while trying to keep weight out of the bow. We will be using about 8 meters of chain with an anchor of 8-10 kilos.
Suggestions and pictures will be very welcome.
Aaron
av aadewar
07 apr 2007 17:39
Kategori: Common
Tråd: Source for IF parts
Svar: 4
Visningar: 14863
Thank you-
We are looking for various hardware, hinges for lazarette and cockpit lockers, also perhaps an outboard bracket. I remember there was a bracket made for the IF transom.
I will try Marieholm Stromstad. Thank you again.
Aaron
